Hello to All. I'm at the end of my wits with this one. I got this motor last fall and went over it during the winter. It now floods the bottom cylinder so bad it won't fire. The plug is good, fuel new, spark fantastic, compression is 95 on the bottom and 92 on top, starts easy, will not run at idle. Runs Ok on top cylinder at start speed but as soon as I try to idle it down it wants to die and engine response is sluggish when I turn the throttle back up. I was getting water in the bottom cylinder but I changed the head gasket and re-torqued the exhaust and there is no sign of any water now. Piston tops and cylinder walls showed no scratches or scuffs. Over the winter I had it running just right. (on both cylinders) Idled nice and throttle was responsive. First trip on the boat it just never worked well at all. A list of the things I've done are
- cleaned carb. and installed a new kit.
- set linc and sinc
- set low speed idle needle
- new leg oil
- water pump
- new plugs
- cleaned ignition coil contacts
- new head gasket
- re-torqued exhaust covers
- spark is white/blue and jumps over half an inch on tester.
- taped the spark plug wires, would have replaced them but they are part of the ignition coil.
- cleaned and lubricated every thing that requires it.
Any suggestions as to what I have missed or should check next would be greatly appreciated. I'm wanting to get fishing. Thanks, Rick.
- set linc and sinc
- new leg oil
- water pump
- new plugs
- new head gasket
