I have Volvo Penta GXI MPI DP Duo Prop. There is no room to see well even with mirrors but water is leaking in at a pretty fast rate. I have inspected the bellows and they look good. My shift cable is getting stiff. I cannot find any pictures of the inside seal. Is this a probable cause and can it be fixed without pulling the engine? Are there other possible causes. The boat has twins and there is little room for inspection and work. Thank You
