pepsigrandpa
- May 1, 2009
- 1
The boys have just purchased their first boat with a Force 125 that won't start. I took a look see and found the rectifier did not look like it was wired correctly. I have a black wire going from - to starter case. I have a red going from +. I have a green W/ yellow stripe on one ac side and another green w/ yellow stripe and a purple on the other ac side. Checked continuity and found the rectifier is bad and both greens are shorted. Is this the correct setup for this device?
