  #1
Old May 26th, 2009, 05:44 PM
dennison17 dennison17 is offline
Default Need help with operation of standard Cobalt depth finder
I have a 2004 Cobalt 240. Can anyone advise me as to how to operate the toggle switches on the standard depth finder to just provide the depth? All I can seem to do is cycle through the shallow alarm and deep alarm.... or set the unit to display in feet, meters or fathoms. I can't get it to just display actual depth. I believe the unit is functioning properly because this happened a year ago, and the dealer got the manufacturer on the line and we were successful in re-setting. This was a hassel. We had to be in the boat with the manufacturer on the phone.....yada, yada, yada. I'm hoping for an easier approach....
  #2
Old May 27th, 2009, 08:57 AM
Mike250 Mike250 is offline
Default Re: Need help with operation of standard Cobalt depth finder
My guess is you have the same depth finder I have on my 2005 250. Pushing down on the toggle moves through the menu options. Once you get to the setting you want to change you toggle the switch up to change set-points.
You probably know this much already but as you toggle down through the menu you'll see something like "Un". Once you see this stop and wait a few seconds and it will show the actual depth.
I have the manual at home if you need details. Let me know.
  #3
Old May 27th, 2009, 11:58 AM
Thanks. I believe it's the same unit. I'll try waiting when I get to the "units" display..... Typically, I've just got frustrated and toggeled up (to select "feet").... and entered into the same cycle all over again. I'll give it a shot today. Thanks.....
  #4
Old May 27th, 2009, 06:46 PM
Hey Mike,
Thanks sooo much. I got the unit to display depth, but only after finagling with it again. I set all the alarms to zero and then it seemed to work just fine. I'm now afraid to touch it!!
I could sure use a copy of those instructions. Is it something you could fax me or send a copy? I'd be happy to forward you $ for your time and postage... Budman
  #5
Old May 27th, 2009, 06:57 PM
Blaze5509 Blaze5509 is offline
are these things just touchy or what?? I took my boat out on our maiden voyage this weekend and the depth gauge was giving me the fits...once I got above about 7-8mph it would start going haywire, once back down under a "no wake" speed, it worked jsut fine...gotta get in there this week and see what thats all about?
  #6
Old May 28th, 2009, 08:42 AM
dennison17, not a problem. I'll go ahead and dig it out tonight and make a copy. Fax or mail is fine with me just let me know where to send it. Glad to help.
Blaze, I'm no expert here but if it gives bad readings it could be the sensor is not glued down well or a loose connection. If it's the factory unit I'm sure it's in the correct spot and glued down well unless it's been knocked loose. If all else fails fill the bilge with enough water to cover the sensor and take it out for a ride. If it reads correctly it may need to be removed and glued down better. I think any air pockets between the sensor and hull will screw it up.
If that's no help maybe you have a bad sensor. What model and year is your Cobalt?
  #7
Old May 28th, 2009, 12:24 PM
Dave1251 Dave1251 is offline
Some Cobalt’s use mineral oil between the transducer and hull. Remove the transducer from the mounting bracket and make sure the mounting bracket is full.
  #8
Old June 2nd, 2009, 01:01 PM
Thumbs up Re: Need help with operation of standard Cobalt depth finder
Mike,
Not sure you received my e-mails sent via the "send a private e-mail" via the iBoat option...
I guess US Mail is the best option...
My Address is:
Bud Dennison
3717 Lake Washington Blvd N
Renton Wa. 98056
  #9
Old June 2nd, 2009, 02:10 PM
Got it. I'll make a copy and send it out tomorrow.
  #10
Old June 3rd, 2009, 10:06 PM
Smile Re: Need help with operation of standard Cobalt depth finder
Thanks Mike.... I really...really appreciate it! If there's anything I can do for you (postage, time spent, etc...) please let me know. I "think" the Private Messaging feature through iBoats. We could perhaps exchange perrsonal details (if needed) via that avenue.
Thanks again. You da' man!
  #11
Old June 23rd, 2009, 06:36 PM
drpeeb's Avatar
drpeeb drpeeb is offline
Quote:
A muddy bottom can cause crazy readings. The unit can't read a continuous depth thru mud.
The sensor could have air between it & the hull; There needs to be none. You may need to remove it, clean it & re-glue it down with epoxy. Also, if there are air bubbles along the bottom of your hull so that the sensor is trying to read thru them, it can't read right.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help with Hummingbird depth finder jklnhyde Electrics, Electronics and Trolling Motors 4 August 21st, 2008 01:20 PM
Help adding a depth finder Steve Andersen Sylvan Boats 1 December 20th, 2007 02:17 PM
Help Reading Depth Finder/Fish Finder Scout Sport Fish Saltwater Fishing 5 July 4th, 2007 09:24 PM
Need help finding an affordable depth finder Atropine Electrics, Electronics and Trolling Motors 1 February 27th, 2004 09:54 AM
Depth Finder Problem- Need Help BeerBarge Boat Topics and Questions (not engine topics) 2 August 4th, 2002 11:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
