Hey guys, I'm going to look at a boat tonight and it will be my first boat. It's a '94 Key West 19' dual console with a 150hp Mariner outboard. I've never looked at an outboard closely so could I get a few tips to look it over? First I'll start it up, make sure it runs well. Then I wanted to check the compression. The boat is two hours away so I wanted to check everything right the first time. Anyone know what socket I'll need for the plugs and how many cylinders this motor will be? Hopefully I have the right size adapter for tester. Also, what readings should I expect from a healthy motor? I know the readings should all be close to each other. Any other tips? Thanks a lot.
