it's an 80 something model. i forgot to winterize and now i can't keep the motor running, it will crank and run for a few seconds then die.
i took the rich/lean box off and sprayed carb cleaner in the carb, mixed some carb cleaner with gas/oil mix and tried to run it through, still the same thing...
it will start run a few secs then die, try to start and it won't start up. i give the primer bulb by the gas tank a few pumps, but the bulb is still hard, go and try to start it and it starts right up, runs a few secs then dies...then the process starts all over with the same results everytime..
PLEASE SOMEONE HELP!!!!!!!
