Re: Fuel Smell in Ski Storage
Don't assume a leak just yet.
You did say that the tank is plastic. Plastic tanks do pass gas right through the wall of the tank. This is the nature of plastic fuel tanks. Granted, it is not much, and under normal circumstances it is never enough to notice, but if the tank is sitting still in an enclosed area like a garage, the minute amount of fuel vapor could collect over a period of time to the point where it can be smelled.
So, I would check for vent blockage, and fuel fill plate seals being good, as suggested by others. If everything checks out, then vent the compartment for a few days, and then check it daily for the smell of fuel. The fuel permeation through the tank wall will not be enough for you to detect it on a daily basis. If you do continue to smell fuel, then there is most likely a leak. Could be as simple as a bad gasket on the fuel sender or cracked fill or vent hose. Or the tank may shift and wear through the plastic.
BTW, I have NEVER read of anyone having a plastic tank develop a leak (except for the occasional mistake with a saw while cutting up a deck). So the chances of the tank cracking or somehow developing a leak without being punctured or cut is slim. Check for leaks at all the mechanical connections first. Although there is always the chance that there was a defect in the manufacturing of the tank, but ALL tanks must pass a pressure test before being released for sale, so that reduces the chance of bad molded tanks from hitting the market.
Have you screwed anything to the boat lately???
