Rotation of dual inboard engines
boatguya1
Re: Rotation of dual inboard engines
To lazy to look it up, but if memory serves correctly the standard rotation motor, when viewed standing behind the flywheel, the flywheel should rotate to the left/counterclockwise.
James
boatguya1
Better yet look at the timing tabs for ign timing rotation is from Before tdc to after tdc.
James
Ayuh,... I can't think of any tattletales til you mount a Starter on 1 of them....
On the Starter,... If the rotor turns the Right way,... It's the right starter...
