  #1
Old May 26th, 2009, 12:13 AM
Ober51 Ober51 is offline
Default 2002 Yamaha 9.9 Four Stroke Electric Start
I jumped on a deal today for a motor. It's a 2002 T9.9ELHA, I checked around and it seemed to be a good motor - and it's in basically mint condition. No scratches, nothing. He said he hasn't ran it in about 5 years, so doing the math it means it's like 3 years old or so. Said he used it a bunch during that short time, but that he literally just had it sitting here for years. I paid $800, but I sold my last Yammy for much more than I paid, so this motor really has only cost me $500 or so. I think I made out well. Just going to have to build up the transom a bit seeing as it's a long shaft.
Seeing as it's sat that long, is there something I should do before I even run it? He said he changed the lower unit oil right before he last used it, but should I change again? Should I run anything in a gas tank to clean it out? Very new to all this, so anything I can do to preserve this thing would be great.
  #2
Old May 27th, 2009, 11:26 AM
Default Re: 2002 Yamaha 9.9 Four Stroke Electric Start
I'm guessing I should change the oil out, change the lower oil and then see if it does a nice solid stream of water. If not, change impeller. Sound good?
  #3
Old May 27th, 2009, 06:46 PM
I am going to change the oil on this motor before I do anything, even starting it. My question is that when I read the manual it said I have to replace the gasket on the screw after emptying the reservoir - I am guessing it's a one time use thing? Second, where do I get that small gasket? Maybe I am totally missing it, but I can't seem to find it. It says, "Put a new gasket on the oil drain screw." and in the picture box it has a part number: 001534. I checked online and can't seem to locate it. Again maybe I'm missing it. Anywhere I should look?
  #4
Old May 27th, 2009, 10:59 PM
sacnho sacnho is offline
The gasket is metric o-ring. You should be able to find them at a napa or the like auto store. Just take the old one with you and match it up. You can order them from a Yamaha dealer put they are around 2 dollars a piece.
  #5
Old May 27th, 2009, 11:16 PM
cousinabe's Avatar
cousinabe cousinabe is offline
is it part #48 you're looking for?? you may also want to check the thermostat #15
http://www.boats.net/parts/search/Ya...ASE/parts.html
this post may be useful as well.
http://forums.iboats.com/showthread.php?t=158086
  #6
Old May 27th, 2009, 11:43 PM
Maybe I am not explaining it correctly, so here is a picture. This is what my manual says for changing the oil. They are circled in red for illustration purposes. Any suggestions? Is this what you were referring to sacnho? Or do they not mean that what I circled and they mean something else? Or do they mean the filter itself and that seal that I have circled?
What exactly are the part numbers that I need to replace? Where is the best place to order them from? The site you gave boats.net?
  #7
Old May 28th, 2009, 09:38 AM
cousinabe's Avatar
part #16, use the new part number O-RING [93210-16716-00]
http://www.boats.net/parts/search/Ya...PAN/parts.html
  #8
Old May 28th, 2009, 10:01 PM
Great thanks. Also ordered an impeller and some seals for lower unit plugs and screws just in case.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 9.9 High Thrust 4 Stroke Electric Start gump218 Yamaha & Suzuki Outboards 6 April 21st, 2009 06:41 PM
2002 60Hp yamaha 4-stroke won't start 60Hp Yamaha & Suzuki Outboards 1 March 13th, 2009 11:47 PM
2002 Yamaha Outboard 4-Stroke - Does Not Start in the Number 2 position gearyg Yamaha & Suzuki Outboards 3 December 24th, 2007 10:55 PM
2002 90 Johnson 2 stroke won't start tctccts Johnson & Evinrude Outboards 6 June 16th, 2007 01:07 PM
40HP electric start 2 stroke Yamaha cowling sockeyerun Yamaha & Suzuki Outboards 3 April 24th, 2001 05:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
