gregginger
- Apr 10, 2009
- 2
im rebuilding my outboard. ive got the carbs off right now cleaning and rebuilding them. the motor would only idle if i set the idle screw around 1000 rpm. ran great on the top end. whenever i shut it off, even if it was warmed up and just off for a minute i would have to prime the carbs again to get it running.
anyway the carbs are stamped wh2-1 top. wh2-2 middle. and wh2-2 bottom. according to the manual it should be wh2-1 on the bottom and the top. is there a difference between the two? jets according to the manual are the same size on all three. fuel tee's off from the pump 3 ways with a hose going to each carb.
any insight would be helpful. also some of the parts are no longer available. anyone have any ideas where to look incase i need something that is?
thanks
thanks
