bstracener
- Apr 25, 2009
- 6
First time poster, looking for some help, thanks in advance. A little background on the engine, it's an 87 Johnson 28 SPL long shaft, I've cleaned the carb, conducted a de-carb on it using sea foam deep creep and sea foam in the gas tank, I have the proper spark plugs (champions), just haven't changed them yet as I'm still working on the de-carb. Well, while trouble shooting the misfire, I switched the plug wires and found a wire somewhat erratic on resistance meter reading. Also, the bottom plug fell off while running the engine at above idle and the engine actually ran smoother than when both plug wires are on. The only thing I have not accomplished yet is the link and sync, it appears the timing is off for the bottom cylinder (#2 cyl I would guess) although, not sure how that would work. Thank you again for any input regarding this.
