ShaneCarroll
- Feb 10, 2009
- 639
Ok, so thank you to everyone who has stuck with me during this process, a process I would not be worried about had the previous owner of my boat done any maintenance whatsoever. Anyways, I'll bite my tongue on that subject. My situation is:
I have removed my Alpha One Gen II outdrive, in order to replace the bellows, gimbal bearing, and u-joints. Got the old gimbal bearing out and the new one in today (not much time to work on the boat, as it is in storage during the week), and removed the old u-joints. While taking out the old u-joints, I noticed that there is a "cap" on each end. Well, I had to pry this cap off of each side, after removing C-clips, to remove the old ones. The new ones also have this cap, however the greasing nipple(?) is located in a different spot.
Is it really as simple as removing the caps off the new ones to stick it in there, and then replacing the caps? Will that damage them in any way? Also, which way do most people install gimbal bearings, slots facing out, or in towards transom?
Thank you again for all the help in advance.
