Can't find Water Pump for 1998 Force 90/120
Leonard281
I have a 1998 Force - Model 90/120 - Serial #OE3355970 and I can't find a water pump for it. All of the Pumps I have found are for up to 1997. I hear it is a rare motor, only made one year. Any help would be graetly appreciated.
P.S. What is the value of this engine??????
Thanks
gjm
Re: Can't find Water Pump for 1998 Force 90/120
Take the impeler out and take it to a dealer to match it. Or go to dollaroffshore.com If the site dosen't take you to the force list, just type them a request on part needed. On top of page, click on parts dept. and go down to parts request. Or call 1-800-376-1616
pnwboat
I ran into a similar problem. Tried to order a couple of kits to no avail. What I ended up doing was I took the lower unit off, removed the water pump housing/gaskets, looked at the shape of the gaskets and compared them to the pictures of the one's listed here on IBoats. I saw picture of an impeller kit that matched my gaskets and ordered it. It was the correct one.
Having said that, I think the reason why you can't find a listing for yours is because it's a Mercury lower end. From the cross references that I can see, looks like you probably need an 18-3214 but don't hold me to that. See if the gaskets pictured here on IBoats for P/N 18-3214 match what you actually have.
roscoe
Mercury part number -- impeller-- 47-43026T2
Water pump kit -- 817275A2 -- $64
Order it online or from any Mercury dealer.
Leonard281
Thank you to all for answering. Your help is greatly appreciated!!!!!!
