pecheux
- Jun 9, 2006
- 1,200
Good day, When trolling for a while the motor gets 'shaky' and produces more exhaust smoke. I beleve, and correct me if I am wrong, this is called "oil loading"
The plugs are new and checking them after a day out shows clean dry plugs with the right sandy color.
I can ajust carbs and it is set centered between lean stalling and too rich (half turn between each)
Using synthetic HPI oil at 55:1 ... would I need to use an oil that is for premix only that burns easier at idle in order to prevent this oil loading ? or use a leaner mix ?
Thank you for your feedback. and have a great day
