Re: 1994 Blue Fin Welded Aluminum Restore
Blue fin is an excellent boat.
Start with finish compound and see where that gets you,with a little elbow grease it should come out pretty good.
I would shy away from sand paper so you don't go through the paint but if the compund won't get it back try some 2000 grit wet and use a little dish soap and let the paper soak for 5-10 minutes first then sand just a little really light then hit it again wiht the rubbing compound.
I would stop there since you don't know how thick the paint is, if you go through you either live with it or strip it all off.
__________________
GO IRISH!!!!
