Re: bonding transom
One more question for tonight. I just ordered (today) some 1708 biaxial fabric that I plan to use for bonding the transom boards to the boat and between each layer of wood. Should I use CSM instead? I thought the 1708 would work well, but can use it for something else if it really wont work for bonding the transom.
I think 1708 already has CSM stitched to the back of it. If I am right than you do not need to buy separate CSM to do the job, it is already attached to the back of the fabric.
A basic fiberglass layup goes like this,
(2) layers of CSM (1) layer of roving (1) layer of CSM to hide the stitched welt in the finished surface.
A layer of csm should always go between layers of stitched cloth, like biaxial.
If memory serves 1708 is made with a CSM layer on the back of the fabric. When you lay it make sure the 1708 goes CSM side down. You may need some extra CSM to cover the welt of the fabric if you are working up to a smooth finished surface.
example= Wood-CSM-CSM-fabric-CSM-CSM-finished surface.
I generally omit using stitched fabrics for bonding. The added fabric will add allot of bulk and thickness that it not needed. In turn it is a good idea to use fabric if strength/ thickness is needed in what you are laying up.
It is not a good idea to lay stitched cloth against stitched cloth. It will not bond well using poly resin. The heavier the cloth the worse the problem gets.
