have a 1997 Sea Ray F-16 Sea Rayder jet boat with a 175 Mercury Sport Jet . I just put it in the water after a long winter and the boat wouldn't Crank over. I thought it was the battery but full checked and charged battery that isn't it. The blower also wasn't working the fuse was blown it was a 7.5 amp I only had a 10 amp so I used that. The new fuse didn't blow but the blower doesn't turn on is that becasue wrong fuse? The blower lite turns on, on the switch but blower doesn't work any ideas there? The boat when I try and start it is very weak seems as there isn't enough power to crank the motor over. Any help with these issue I would be greatful!!!
Also if anyone knows of a good and honest boat servicer in Northwest Indiana or the chicagoland area I could use that would also be a help since I don't know much about motors.
Thanks Rich
Thanks Rich
