Re: 1986 60HP Mercury - Near Top Spark Plug Water Leak
Is it possible a previous owner removed the sensor and someone drilled thru the metal to reach the water? I know it sounds crazy. If water really is coming from the threaded hole that was for the heat sensor (and I am not sure this is the threaded hole in question), and you do not have or want a heat sensor, I guess you could just plug the hole w/ a bolt.
Also, on my 40, the rubber pee hole tube attaches to the block above this heat sensor, could that be your source of water?
__________________
1995 Merc 40 hp 4 cyl 2 stroke ELPTO
Serial # OG240587
16 ft. Duracraft bass boat
Mostly used to give dogs a ride.
