ahayesb
- Apr 27, 2009
- 1
Got a 1973 Johnson 9.5 given to me and it needed a fuel pump. Repleced the fuel pump, still wouldn't stay running, cleaned out the carb and replaced parts w/ a rebuild kit, wouldn't stay running, made sure points were set @ .020 and the timing was set correctly, wouldn't stay running, checked all the fuel lines and fittings in the motor and leading from the tank and it still wont run. If I hold my fingers over the choke it runs fine, but when I remove my fingers or use the manuel choke the motor only runs for a few seconds, acts like its not getting any fuel. All the lines and the card are clean. Plenty of fuel pumping from the lines, and filling the bowl. Any ideas of what else I can try/do? Something Im missing? Need some help please.
