Re: chrysler 60HP model 609HA
Check for clogs in the fuel system and replace the fuel pump diaphragm. If that doesn't help, clean the carbs.
It (The engine) is running out of fuel and when you idle, it catches up. When you go to full throttle, it runs out of fuel again.
