  #1
Old May 23rd, 2009, 02:56 PM
info404 info404 is offline
Question 81 mercury thunderbolt 40hp tell tale info
in the past i've found a wealth of info in this forum. so this is the first time i could not find an answer on my own and look to your expertise in helping me. my outboard motor ser# starts with 599, i recently installed new impeller, fuel pump, prop. my tell tale does not work, the lines run from the tell tale, of course ,to the fuel pump houseing. is that right? its what it shows in the manual also. checked it up down all around and it seems if it was to work it would be running water directly over the fuel pump. which i guess, if the diafram ripped it would flood my engine with water. is it possible this model isn't supposed to have a tell tale? if so, why is it there, to vent the fuel diafram?? i don't get it, please help figure out something that i must be missing. thanks in advance...04
  #2
Old May 23rd, 2009, 09:08 PM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
Default Re: 81 mercury thunderbolt 40hp tell tale info
Mercury did go through a few years where they routed the water flow through the fuel pump. For fuel cooling purposes I suspect.
The blue lines on attached diagrams are water lines (red are fuel lines). Check the water lines for blockages (bugs, debris).
You may also have a thermostat and poppet on that motor. Might be a good idea to inspect them, as they -might- interfere with telltale flow. Not a bad idea to look at them periodically anyways.
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
  #3
Old May 24th, 2009, 12:47 PM
WOW, that is exactly what i needed. i thank you very much. wish i had that diagram to begin with. again thank you...04
  #4
Old May 24th, 2009, 10:37 PM
took a look at it again thx to the diagram you sent, followed all the water lines and finally found the block in the fuel pump houseing. tell tale pees like a pro now. thx...04, oh yeah, i also noticed that the houseing does not flow over the fuel pump diafram, its a separate channel in the houseing
  #5
Old May 24th, 2009, 11:30 PM
AMD Rules's Avatar
Glad to hear you got it sorted out...
Pay it forward.
Happy Boatin
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Water Spray below Cowl on 81 40hp Mercury MuddyWaters Mercury & Mariner Outboards 4 February 11th, 2009 08:41 PM
80-81 Mercury 40hp No Pee NSG14RYDA Mercury & Mariner Outboards 10 March 22nd, 2008 10:41 PM
1980/81 mercury 40HP lower unit stuck jahughes Mercury & Mariner Outboards 1 August 15th, 2005 05:52 PM
Mercury 40HP Thunderbolt Question bbalaska Mercury & Mariner Outboards 3 August 2nd, 2005 03:10 PM
Mercury 650 Thunderbolt... Water Leaking.. tell tale is weak, Diagrams included chewbacca Mercury & Mariner Outboards 10 July 29th, 2003 09:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
