Re: 1987 Glastron Restore
So I have some pictures but they are stuck on my camera until I find the adapter to get them off. I tried putting the memory stick into my laptop but it doesn?t read the Don?t Pro Duo.
This is Day two of the boat remod. I hooked the garden hose up to the motor and tried firing it up. Even though it has been sitting for a couple of years that bad boy fired right up. I didn?t want to run it for very long due to the old gas that was in there but I revved it up to about 3500 RPM and then shut it down.
All of the carpet is now removed. Also, I cut out the fiberglass around the deck ply and I think I?m in for a lot more than expected. The foam under the deck is saturated with water and cause the entire deck to rot. The stringers are in rough shape not rotted because they are mostly covered in fiberglass. I think that I am going to go ahead and cut those out as well since they are exposed and easy to get to.
Back Aft: This is where it is getting tricky, I wish I had the pictures; anyhow, I cut all of the wood out except the flat area where the gas tank sits. It still looks pretty good. A little wet but not rotting. The trans looks pretty good as well. So I think that I am going to add a piece of Ply to the Trans just to beef it up a little and prolong its life. It will be a head ache to remove the motor and split the hull If it isn?t needed. I may use the synthetic stuff later on down the road.
Questions for today:
Foam- Is there a good reason for it or is it just to rot stuff out? I can make storage space out of the rear compartment if I don?t replace it.
FiberGlassing. When I replace the stringers how many layers of glass do I need to put down?
