volvo dps to much fluid
bahafisherman
I changed(incorrectly) the lower unit fluid on my 92 baha cruisers 570A volvo dp. I am fairly certain that i over filled it. Cant get to dip stick while in water. Took it out for maiden voyage rev. good, neutral good, forward good than ran about 6 miles and wouldnt shift out of forward (stuck in forward). IF I pull it back out and make sure level is correct do you think it will be ok? or did i cause more damage. just trying to save a few bucks by not putting it back on blocks. Sure was fun trying to dock it on my own. Thanks in advace. great forum
captmello
Re: volvo dps to much fluid
I've had trouble getting out of forward on occasion like you. I can't tell if its in the control or the oudrive.
Did you confirm the fluid was too high?
