actionjackson
- Apr 2, 2009
- 37
'62 rk 24 40 hp, man that flywheel was in there, ended up breaking a bolt in the flywheel, luckily got it out, and continued. I used a sleeve on each bolt the 2nd time around to snug the puller to prevent side twist, worked great and after using an air gun and a tap air gun and a tap it finally broke loose. points, condensors, coils and wires installed and spit and sputter and it started. now to start other checks on driveline, thanks BIG TIME to the helpers here on iboats johnson forum.
