  #1
Old May 22nd, 2009, 01:10 PM
softtop softtop is offline
Default Weird Gas tank problem FS165
On my last fishing trip I decided to fill up the boat tank at the gas station. I placed the nozzle in the fill up spout and locked the hose nozzle to on. While it was filling I decided to clean the car windows. When I returned to the Boat I noticed it filled up about 20 + liters (over 5 gallons) and it was still filling.
I expected only to top up around 2 or 3 gallons tops. Anyways I stopped the fill and headed to the lake. On the lake there was a huge gasoline smell coming from the boat (I've always had a minor gas fume smell coming from the rod locker but not like this). This was heavy enough to make you sick. After a 20 minutes I returned to shore to check for gas leaks. I noticed the Rod locker carpet was soaked with gas and there was also about 1 gal or so in the bilge. In fact my float switch for the bilge pump was melted. Man this was Scarey. I could have easily gone up in flames or worse had the float switch turned on. Luckily the gasoline melted the lever stuck open.
I am not sure how the excess gas ended up in the boat without spilling out from the top of the spout while it was overfilled. I checked the Gas hose and air hose at the tank and they are both secure with no movement. Same with the connections at the Spout and the connection from the tank to the motor gas line.
Has any one else experienced this with their boat?
Thanks in advance
ST
  #2
Old May 28th, 2009, 10:01 PM
DeepV DeepV is offline
Default Re: Weird Gas tank problem FS165
Wow, that is something!
First of all, I never leave a pump unattended even on my truck. Bad things can happen out of nowhere. Try and always monitor the situation while you are pumping gas.
When you got back to the filler spout of the boat, what was it doing? Did the automatic shutoff kick in? If so, you may have filled your tank plus the rather long large diameter filler hose. After running down the road or lake, it may have wiggled slightly loose somewhere.
Also, there may be a vent valve on the tank to allow room for expansion. Gas coming out of the ground is cooler this time of year than the outside temps. You may have overfilled it and it expanded running into the bilge.
Either way, it is a dangerous situation. In all cases, overfilling a gas tank is a bad idea.
Keep us posted if you find anything else.
__________________
2008 Lowe FS 175 with 115 Optimax
  #3
Old May 29th, 2009, 02:08 PM
Thumbs up Re: Weird Gas tank problem FS165
Thanks DeepV for your reply.
I did some more checking and this is what I found. On Saturday May 23 I went out on the lake and ran about 15 miles on the boat. When I came back I added 10 liters of gas (5 gals) from a gerry can (slowly). Everything seemed OK no gas in the Bilge and No gas in the rod locker.
I opened the floor access port to the Gas gage Float switch. I decided to remove the float switch and check how much gas was in the tank (The gage shows full but anything above half a tank registers as full). As soon as I loosend the first bolt gas fumes started hissing out from the bolt thread area followed by some gasoline. I re-tighted the bolt and left it at that. So it looks like the tank is under pressure. So at least I know its not a hole in the tank or a loose hose connection.
Your suggestion of the gas coming out while I was driving seems to make sense. More then likely the gas was in the filler hose and while I was driving the gas warmed up, expanded and forced its way up the vent hole and down inside the boat into the rod locker and then settled in the Bilge area.
  #4
Old June 16th, 2009, 04:04 PM
overload overload is offline
In my FS165, the gas tank ventilation tube just flopps around in the bilge. It is likely that you overfilled the tank and it overflowed out of the vent tube and into the bilge. I noticed that when my boat has been sitting around for a time, I got a gasoline odor in the bilge and storage lockers (not good!) and traced it to the vent tube. Ideally, the vent should be in a loop back to the fill port similar to a car, or vented out of somewhere higher than the tank, definetly not in the bilge. I have been meaning to fix this but in the meantime time I have the vent tube routed into the rod locker and out the locker door during storage and tuck it back into the bilge when I'm on the water.
  #5
Old July 7th, 2009, 01:04 PM
Irv964's Avatar
Irv964 Irv964 is offline
Quote:
This is good to know, I will have to check mine out this wknd, although I have never had strong gas odor's or the like, I can faintly smell it in my middle console floor compartment.
Also I usually only fill my gas tank just over slightly half,(by the gauge) I find it lasts a good long time there, especially with my 4 stroke and there (imo) is no need to be carrying that extra weight around? (This is just my personal reason, I do not do long boat trips, mostly tubing, skiing, pleasure)
__________________
2006 Lowe165 F&S
2007 90 Merc 4 stroke
19P Turning Point Hustler Prop
  #6
Old July 16th, 2009, 11:14 PM
willrush willrush is offline
FS165 2004
Bought the boat Memorial Day and noticed the fuel gauge does not work. I read on a previous post the gauge only works when you get below half tank. Is this true?
I have also noticed the smell after topping off the tank. I am going to run the tank down below half way and see if the smell improves and gauge works. I'll repost soon.
  #7
Old September 15th, 2009, 09:03 PM
My gas gauge works fine, though like on a car the top half of the tank is bigger than bottom half.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gas tank vent problem KJM43 Sea Ray Boats 2 April 24th, 2009 02:34 PM
Gas gage problem on 2004 lowe FS165 softtop Lowe Boats 2 July 10th, 2008 09:57 AM
Gas tank problem Roger Sr Johnson & Evinrude Outboards 16 May 15th, 2008 12:21 AM
gas tank problem dmarshin Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 6th, 2007 06:56 PM
gas tank problem EDGE699 Boat Restoration and Building 9 April 13th, 2007 03:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
