Re: How to find / repair leak on aluminum boat
You probably have a rivet or two that may need to be tightened or replaced........
Your seams could be letting water in.....
You might have a hole, a tear, or a spot that is worn through.....
The best solution is to identify the leaking spot, take action and then apply gluvit to the inside (and sometimes the outside) of the leaking area. Gluvit applied to future areas such as seams and rivets is a pro-active approach.
If you use the search function and type in gluvit..... you will become very familiar with it.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
