FishBone72
- Apr 26, 2009
- 4
1972 Robalo 19' CC w/ 1983 Evinrude 175
2 weeks ago I took a trip to Hilton Head and after a long day of 3'-4' swells and 20 mph winds I was cruising back through a long stretch of no wake zone and I believe my motor overheated. I smelled something like burnt hair and looked back and saw more than the usual amount of smoke. I immeadiately turned the motor off and trolled back to the boat ramp on the minn kota (which took about an hour). I figured the motor should be cooled off by then so I started her up and everything seemed ok.
The next day I cruised through the bay for a little while at around 25mph no problem. After about an hour the motor choked out and was difficult to start again. Once I got it going she would only run 10mph at full throttle all the way back to the ramp.
Once I got home I hooked the motor up to the hose and started it up. It sounds like its running pretty crappy so I do a compression check.
Heres what I got:
1) 55 1) 87
2) 92 2) 95
3) 95 3) 90
Any ideas as to what could have caused it to overheat?
Im not really sure where to go from here, but im afraid I may be looking at a rebuild / repower situation.
Heres what I got:
1) 55 1) 87
2) 92 2) 95
3) 95 3) 90
