So we were out on the lake today (first time on the "big" lake, have been staying on a smaller local lake up until now). We are cruising along at 20mph, 3800 rpm. All of a sudden, out of nowhere, a big impact. I was sure we had hit a tree stump or something. The engine continued to run, but rough. We made it to shore to survey the damage - and found nothing. No nicks, no scratches, no sign whatsoever of an impact. The prop was brand new so I would have know had it been nicked.
I tried to restart the engine and it would start and run in fast idle. But when I moved it to neutral and tried to put it in gear, it stalled. I tried this several times with the same result. I was able to finally get it in gear by revving it in neutral and then slamming it into gear. Once in gear, we were able to motor along back to the dock (about two miles). The engine was running a bit rough but it seemed to be powering us along OK. When we got to to dock, I killed the engine and then tried to fire it again. It fired, idled, went into gear, and ran with no problems!!!! It is running maybe a bit rough but other than that, you wouldn't know that a half hour earlier it wouldn't even idle or go into gear. It has full power and goes onto plane just fine.
I have to admit, I a bit stumped. I went from thinking that I hit something to thinking that perhaps I threw a ring to not having a clue what happened.
Any ideas? The wife and kids won't go back out until I figure this one out (can't blame them) so it might as well be dead in the water
Help!!!!!
1993 Four Winns 180 Freedom with 1993 Evinrude 115TLET
Help!!!!!
