oil alarm
nursing
i have a 175 hp johnson ocean runner oil alarm keeps going off,dont want to blow motor,can i disconnect oil injection and if so how is it done,and what is the ratio of gas to oil
nursing
Re: oil alarm
i have a175 hp johnson ocean runner oil alarm goes on and off ,replaced oil tank and lines this seemed to help for awhile,i want to disconnect vro and start mixing oil with the fuel dont want to blow motor ,how do i go about doing this
o/b tech
Re: oil alarm
At what interval is the alarm going off and did you purge the air out of the oil line going to the pump when you replaced.
o/b tech
Re: oil alarm
Low oil alarm is a beep every thirty seconds
No oil is a beep every second
Overheat is a steady alarm.
kenmyfam
Re: oil alarm
Premix the fuel while you diagnose the problem just in case you fry the motor.
