Re: Will test running high RPM on water hose cause damage to engine?
+1 for JB. The reason for not running at high speed doesn't have to do with water supply, it has to do with high rpm in an unloaded condition.
Water hoses even at the 60 PSI of a well pump have enough volume to keep an outboard cool. However, without the load on the propeller, the powerhead and lower gear box will overspeed. When the design load is exceeded, the engine will start to disassemble itself.
I have witnessed the results of engines coming apart and IT WILL CAUSE GREAT BODILY HARM OR DEATH.
There really is no reason that you need to run an engine in gear out of water. If you want to see if your prop turns, rotate the flywheel by hand with the shifter in gear and THE IGNITION SWITCH IN OFF.
If this seems a bit harsh, it is meant to be. I see too many bodies from the results of accidents that could have been avoided if they used some common sense.
John
