rsimmons42
- Aug 25, 2008
- 194
First and foremost, I do have the original service manual for the engine. Does not cover this. So please answer...
I have a 1977 70 hp model 70EL77s
I took the boat down to the water and backed the boat down into the water and left it tied down to the truck. I set the lower end timing and the set the idle.
Here is the setting of the advance.
Stuck the motor into gear and gave it WOT and set the advance to the spec. of 17 deg.
HERE IS THE PROBLEM. with all of the load the motor will only go up to 3500rpm. but the timing base is moving forward to a stoping point and now is set to the above mentioned.
Here is the Question. Is it normal for the boat tied down to the trailer to not go all the way to 5000rpm, due to the increased load.
AND THE COMPRESSION IS GOOD. I have all new ignition system, hince the reason for the tuning.
Please advise.
Please advise.
