Knynhandler
- Apr 24, 2009
- 4
well you have 2 cables, shift cable and throttle cable, sounds like shift is working. problem with throttle cable, or linkage. i would really be nice to have all the details.
http://forums.iboats.com/showthread.php?t=250879
A little more info:
Does it even rev up?
Does the throttle go forward, or is it stuck?
Pull the hood and advance the throttle to wide open while watching the linkage. Does it open up the carbs? There is a cam that pushes a roller to open the carbs, if roller is loose on its adjustable base it might not allow carbs to open. Sounds like linkage or cable problem.
James
