hello im new to this so here are a few questions i have, how do i replace the impeller, also how much will a small air leak in the gas tank affect the engine? i bought it with a shell lake dart 59 for $600 im trying to restore it on a budget haha. I took it out yesterday and it was a pain to get started (pull start, the starting solenoid or relay or whatever it is was blown when i got it) and when i did get it started it would sputter then die i adjusted the low carb setting got it to run and took it out for a while then it died once i lowered the rpm when i entered the no wake zone (yay for paddles haha). i replaced the fuel lines resealed the gas can and here is one final question i knoticed the carb settings have a stop on the intake but when i got it the high speed was missing the stop so i need to know what are the settings to put them to so i can get her running good again? for instance high needs 1.5 turns out from closed thanks in advance for all of your help.
chris
chris
