  #1
Old May 18th, 2009, 10:58 PM
alaskamarine alaskamarine is offline
Default yamaha 150 blown head gasket??
Was out in the bay last night for a quick night of fishing when cruising, 54mph @ 4700, the oil pressure alarm sounded and I shutdown the engine. Switched to the kicker and started to make my way back. About halfway swells were starting to be a concern with the kicker not having enough power to power through them, so I had to switch back to the 150, started up fine and made it back to shore, about 10 miles. Checked the oil this morning and it was full to the top of the dip stick, as well as milky. Tried starting it and it did not want to start. What could be the cause of this? It is a '05 150 four stroke.
  #2
Old May 19th, 2009, 12:41 AM
mdunn mdunn is offline
Default Re: yamaha 150 blown head gasket??
The pro's (I'm not one )are going to tell you to do a leak down test to determine what's going on.
You may now how they work already but in case you don't.
Good luck!
http://www.vmaxoutlaw.com/tech/leakdown_tester.htm
  #3
Old May 20th, 2009, 07:10 AM
Did not hold pressure in the leakdown test, compression was low in two of the four cylinders. At minimum I am guessing I will be having the mechanic replace all four pistons and engine gaskets, as well as have them send out the cylinder block for replating...if possible, and rebuilding the crank with new bearings. Any estimates for the parts + labor? First time having the engine in for repair. I have to pay $1,000 in shipping charges to get it flown to the dealer 550 miles to the south, on top of whatever it will cost to get it repaired.
  #4
Old May 20th, 2009, 10:13 AM
Ouch! That's gotta sting.
Where's Kiana, AK? Sotheast?
You sending it to Seattle?
Good luck man.
  #5
Old May 20th, 2009, 08:26 PM
Sending it to Anchorage, I am about 60 miles above the arctic circle on the arctic ocean.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 yamaha 150 head gasket replacement Reelcs25 Yamaha & Suzuki Outboards 4 March 29th, 2009 04:15 AM
89 XR-4 150 Blown head gasket venture Mercury & Mariner Outboards 5 June 7th, 2007 10:26 PM
Blown head gasket? Navgunner Johnson & Evinrude Outboards 13 July 29th, 2005 09:52 AM
Blown head gasket ????? fireman_103 Johnson & Evinrude Outboards 4 September 19th, 2004 06:32 PM
blown head gasket 130 hp yamaha the mailman Yamaha & Suzuki Outboards 1 June 10th, 2003 11:25 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
