drtystrcrft
- Apr 22, 2009
- 2
Hi there, I've been using the site for a few years but never posted anything til now! It has always helped me out, but I haven't seemed to find anything quite like my problem. I purchased a '75 25hp short shaft last summer for $50... absolute no brainer.... the shift lever/shift shaft was broken off when I bought it so I had that replaced, and had a basic look through done. I took her out and I just got up on plane and it popped out of gear... the shift lever moved slightly and the motor was in neutral, I put it in gear and it did the same thing... so I checked linkage and adjusted the shift lever and I still had the problem... I took the lower unit off today and it looks fine to me, besides normal wear... I thought the prop might have spun so I jammed the flywheel and I could turn it slightly but it wouldn't spin on the hub. I'm clueless here any help would be appreciated fellas!
-Ryan
-Ryan
