110 hp mercury runs rough high rpm
allenprimo913
hello,
i have a 110 hp 1966 inline that runs rough if rev at high speed, but at idle it runs smooth and idle good but when you accelerate it doesnt response right.
starts everytime, i not sure exactly what suppose to be the adjustment for the carbs, i have the 3 side carbs and adjusted at 3 turns each. relpaced with new plugs too.
what could be the problem? help:confused:
thnks
daveswaves
Ensign
Re: 110 hp mercury runs rough high rpm
hello,
thnks
Since you are having trouble getting this question answered lets try and get some help. You say it runs rough if you rev at high speed. What do you mean by rough? What RPM do you consider high speed? Does it gradually die out, does it cough or spit when you accelerate?
You have adjusted the carbs 3 turns each, if that is 3 turns out from lightly closed then you are probably still too lean.
Without information from you folks can,t answer your question. This will bump your question to the top again, if you add more information you will likely get an answer.:)
gator1959
don't just isolate the problem to carbs,sounds like it could be a rectifier or electrical issue if it only craps out at high rpm/s
