Re: oil leak on 4hp
If it is gear oil it is a problem, if it is unburned outboard oil it is no problem. You need to be a little more specific. Posting pictures always helps. If oil is leaking out from your gearbox then most likely water is leaking in as well. Drain your leg oil and check for water. If it is OK, then most likely it is unburned outboard oil.
Have a great day,
Rob.
