skeeter sx 190 Water Gauge
mikebabin
Ran my boat for the first time this spring. Water guage does not start at 0 PSI, is starts at 25 PSI and goes up from there. Won't return to 0 when key is turned off and on. Do I need to replace this or is there something else that I can do? Thanks for your help.
Silvertip
Re: skeeter sx 190 Water Gauge
The water pressure gauge is not electric. It works on water pressure. Disconnect the tube at the back of the gauge and at the engine. Blow through it to clear any obstructions. With the tube disconnected the gauge should show zero. If it doesn't the gauge is toast.
