let me first say, i am new to this site and boating in general. while friends and family have owned boats, i have never personally owned a boat until recently.
some background:
basically, a co-worker gave me his old boat, a 1988 18' starcraft walk-through, when the engine stopped running. i took the boat with the idea of rebuilding the motor and using it for several years before buying one of my own. upon a tear down of the engine, a 1987 90 hp 2-stroke 3-cylinder outboard, i found a piece of the top of the #1 piston broke off and prevented the rotating assembly from making a full revolution. since it didnt seem like a major problem, i began rebuilding the motor.
the problem:
upon completion, i re-installed the powerhead and all the attaching hardware, wiring and brackets. when the motor is cranked, it will only start and run with the trigger arm moved approximately one inch counterclock wise (always starts and runs in this position). this causes two problems: one - the trigger is not in the idle (resting) position in relation to the throttle arm. second - the motor runs at or about 1500 rpms (700 rpms is spec).
my thought is the stator was not installed in the correct position. any thoughts would be appreciated. thanks.
some background:
the problem:
