Re: Shifting Prob Evinrude
There's an oval cover on the starboard side of the midsection that you take off to get to the shift rod disconnect. Be very careful when you reinstall that you get the groove in the rod matching with the hole in the connector before you install the bolt or it will rub off the bolt threads. It does sound like your adjustment is off, but it could be a connector problem or possibly a bent linkage. Better be careful you get the water tube back in the water pump housing upon reinstallation as well--common error.
Good luck,
JBJ
