bob johnson
- Feb 25, 2009
- 4,304
how much can you take off a head for a 1988 70 hp evinrude??
there is just a little pitting in between cylinders. plus there was some debris smashing into the the head by the piston after a recent rebuild...
it seems pretty flat now....
I can cut it at work with not much set up...but i dont want to throw off compression too much
the block is bored .040 over already... from a previous to me rebuild.
I am putting new rings and one new piston in..
also the reed things....what should I be looking for , to see if they are in good shape.
they are nice and clean no pits or burrs...nice round edges...
one more question, do i need a special heat resistant primer and paint for painting the head... and block
I have the head all sand blasted now....
I have been doing every pieces i can seperate and have been priming all aluminum pieces with INTERLUX Primocon underwater primer.
I am on the motor parts now which mostly were black.
previously I over painted with Evinrude blue for all the non power head parts
thanks guys
bob
thanks guys
bob
