mack bolan
- Apr 20, 2009
- 2
I have a 1982 140hp evenrude outboard, on monday i start it no problem run for about five minutes and i turn it off wednesday i took it to the ramp to go fishing would not start, everything else work tilt and trim, light, instrument panel, fishfinder. when i check the ignition switch none of the six wire has a live feed, i run a wire from the yellow and red wire straight to the starter seloinoid bypassing the nutual switch and still nothing not even a click, i was able to start the ingine by jumping the positive from the battery thats on the starter seloinoid to the yellow and red connection thats on the seloinoid so i know the batteries are charge and the starter is working. its like the keyswitch is not getting any power. the starter and the seloinoid is fairly new put them on the engine in december and was able to use the boat a couple times, the ignition switch has 6 connection which goes into a harness which goes into the motor. i just bought another switch today but before i make the switch i wanted a second opinion, if the battery switch is turn on one or more of the wires on the ignition switch should have a positive reading is that correct. any help would be greatly appreciated. and thanks in advance
