2001 fitch 225 stops running
ohmy
hello I have a 2001 225 there is no reym or reason but it will just stop running wheather i am idealing or on plain weather it has been running for 10 min or 2 hours when it stops it will not crank of do nothing the lites go through the cycle and then they come back on and stay on the last time it quit for about 2 hours before it restarted ran for 1 hour on plain at 48hundred rpm then quit did not start until next morning like i said it will not crank but the gauges work so it is not in the key any help is the emm going or is the a wire shorting thanks ohmy
Faztbullet
Re: 2001 fitch 225 stops running
Check the fuses and relays on the PDP(POWER DISTRIBUTION PANEL) This are know for failure due to solder breakage.
