1989 3.0 OMC timing tab decayed. can someone give me the numbers??
Onebadpolaris
I have a 89 OMC 3.0 cobra and im trying to check the timing but the timing tab is so decayed I cant pick out one number on it. Can someone give me the numbers in order so I will know what degree it is. Thanks, Austin
Bt Doctur
Re: 1989 3.0 OMC timing tab decayed. can someone give me the numbers??
If your looking at tha tab,there should be one notch thats bigger/deeper than the rest.That should be "0", furthest to the right.Going to the left notches should be 2,4,6,8
Don S
If it doesn't have one notch deeper than the others, Just count the notches. They should look like this.
attachment.php
Onebadpolaris
Hey thanks alot! It was the one that didnt have a bigger notch. Don S hit it right on the nose, I dont know where you found that picture, I looked everywhere for one. But thanks!
