kgillespie
- Apr 17, 2009
- 2
I read the FAQ on adjusting the carb and it was very helpful I just have one more question.
I bought a 1961 Gale 5 hp Buccaneer. It has full forward, neutral, reverse shifting so from what I have been able to learn it should be the same as a 5.5 hp Johnson.
I starts very easy and runs just fine in the start position and the fast position but will die if I move the controller on the tiller to neutral, shift or slow it will die.
From looking thru the inspection hole, the coils are light green and look new and the carb looks like it may be have been rebuilt. The guy I bought it from said he planned to run the motor but didn't know how to change the water pump and it wasn't pumping water. When I changed it the impeller was new but it needed a hole new housing. So I think he changed and rebuilt everything and it now just needs the carb adjusted.
My question is when I adjust the slow speed on the carb, what position do I want the tiller control in? Start, Neutral, Shift, or slow. If anything but start, how do I keep it running to adjust the carb?
Thanks
This site has been a great help.
Thanks
