'95 Mercury 175 EFI miss/power loss
Ok. Here is goes! 5 months ago I started having a miss begin, it first showed up while idling along @ 6 m.p.h., but it would go away in 30 seconds or so. Slowly it started getting worse. Now it goes on for 30 - 40 mins missing then like a switch is thrown...clears up like nothin happened (until I come off plane again!) It never does it when first started, only after at least 10-15 mins. of run time. When it does it, it feels like a dead miss and I can not get over 1400 rpms (will not plane-out). I have so far: (1) replaced stator (2) replaced trigger (3) replaced switchboxes(both) (4) replaced rectifiers (5) Had merc dealer diagnose it---(reset TPS, sync n lync,set timing---still doing it & they said everything is fine (6) compression is good....cylinder leak down is good......(7) all fuel filters replaced and primary fuel pump rebuilt (8) all grounds good, connections good
Miss horrible now....I have been sayin all along the ecu is bad and not triggering the injectors...Any other ideas???????? I am about to drive 3 1/2 hours to Richmond to have Sanderson look at this thing, as I can't trust anybody around my area in Maryland! Any help is appreciated!!
Viper
Reason: wrong wording
