tswiczko
Master Chief Petty Officer
- Feb 15, 2009
- 838
I'm back to pick your brains. I have an 89 Mach-1 Magnum MV2450 that desperately needed a deck. I've several of the threads before starting and learned that I should probably check the stringers too. After I removed what was once wood, I drilled into the top of what appeared to be a stringer (runs the length of the boat , are 2 3/8" wide and has floatation foam bftween them). But they are hollow and no wood in them( I jumped out of the boat and looked at the hull to make sure I didn't drill through the wrong thing ) is this common to not have wood in the stringers? Or am I in real trouble here?
