Started getting boat ready for spring and found two freeze plugs in the bilge after starting engine and running it for about 10-15 mins. it did freeze this winter here. Checked dip stick for milky oil and seemed fine. When referring to milky is that talking about the color or the consistency of the oil. Anyways I took the oil filter off and oil seemed fine. Drained a little from the pan and it seemed fine. No discoloration just a little thin. Is that a good sign that I don't have cracked block? how do I get the freeze pugs back in? Thanks.:redface:
