Intermittent connection
FreeBeeTony
I have what appears to be an intermittent connection on the ignition module (mounted on the port riser).
If I move the harness while the engine is running it dies..........will need to pull the connector and check.
Anyone else have this issue?
Bt Doctur
Re: Intermittent connection
Use waterproof grease, dielectric grease, vasoline, something.
Don S
I don't have one, so don't have the problem. But I have replaced a number of those harnesses. Most dealers keep them in stock.
