  #1
Old May 15th, 2009, 04:00 PM
JPR JPR is offline
Default Century 3200 WA
An alarm sounds whenever I reach cruising speed. It is coming from somewhere in the cabin. Anyone have the same problem? Any ideas what is causing the alarm?
  #2
Old May 26th, 2009, 12:07 PM
FlyboyJr FlyboyJr is offline
Default Re: Century 3200 WA
I just purchased a 2002 3200WA... I am getting the same thing (I think) ... A loud squeel coming from inside the cabin while up on plane. I have isolated it to the thruhull valve for the waste tank. If I close the thruhull valve on the waste tank(macerator output), I don't get the squeel anymore. The actual noise sounds like it is coming from inside the Air Conditioner compartment right below the stairs. I am thinking about putting a one way check valve on the line going to the thruhull valve. I will let you know if it works...
  #3
Old May 29th, 2009, 02:51 PM
Just got off the phone with Tommy Thompson (tech support at Century)...
The fix is to close the output valve, like I stated in my last post(macerator output). He says that this noise is coming from the vacuum break (upside down U in AC compartment). He also stated that you could change out this U with a new one and out of about 12 that 11 of them would squeel. It is air going out and making a whistle sound through the valve. He also stated that you could disassemble it and grease up the rubber part inside and it would get rid of the sound temporary, but it would come back.
So my point is a check valve in the line won't work. The flow would still be in the same direction as the check vavle.
I am now thinking about a 12 volt solenoid valve that would be normaly closed and would only open when 12 volts is applied. Conect the power from the macerator pump to the solenoid valve. Then the 12 volt valve would only open when the macerator is running.
  #4
Old August 29th, 2009, 07:11 AM
gas can gas can is offline
Closing the seacock on the waste discharge works. Manipulating the Y-valve did not produce the same results but I am suspecting it is compromised and needs replacement.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 Century 2300 WA sean117 Century Boats 1 May 15th, 2009 12:46 PM
1999 Bayliner Trophy1802 WA versus 1997 Sea Pro 190 WA jofish Boat Topics and Questions (not engine topics) 3 May 3rd, 2009 09:48 AM
Century 3200 CC - Listing to Port Reel Dreams Boat Topics and Questions (not engine topics) 1 September 10th, 2008 01:23 PM
2000 Century 2300 WA Purchase? Dexter Morris Boat Topics and Questions (not engine topics) 0 August 14th, 2007 03:45 PM
Wa,wa,wa,wa,wa, 2500 Rpms AQUASPORT17.5 Johnson & Evinrude Outboards 9 July 31st, 2007 05:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
